We are expecting some outages while we perform some upgrades. Shouldn't be longer than a few hours, starting at 8pm MST May 6.
Last summer during a Solarbotics Robotics for Educators session, one of the teachers noted something about many of the mainstream robotics and electronics learning platforms commonly used in classrooms. He said that those platforms suffered from the Black Box Effect. This effect was where the “black boxes,” the controllers, were plugged into the computer and worked... like magic.
The hacker community knows it isn’t magic, but the question posed was how do we introduce students to this level of technology?
This is where the SeeedStudio's Grove system of electronics comes in. There aren't any fancy enclosures to obstruct your view of the components that make the electronic systems tick while maintaining a fairly robust connection method to make assembly quick and almost error free. As proven as the system is, teachers had to develop their own resources around the system, and continually scour the Grove Wiki for improvements to their documentation and sample code.
To address this deficiency, we’ve developed The Solarbotics' Grove Education Bundle which is a fully functional Robotics, Programming and Electronics class developed with junior high and middle school student in mind. Solarbotics produces this in conjunction Mr. Mitch Way of Nelson Mandela High School - a practicing Robotics teacher in Calgary, Alberta. It differs from traditional “How To” guides on Arduino by being written by a teacher for teachers and home educators who are new to Robotics. This bundle lays out a full series of lessons complete with:
The assessment guide has been aligned with the new Alberta Career and Technology Foundations (CTF) curriculum and draws heavily upon formative, competency based assessment. Any teacher can be a hero at staff meetings when you can use all of those buzz-words in a single sentence. The complete Teacher Guide includes:
Slideshow example above
The lessons are designed to be used with the Grove system of electronics and the Solarbotics Sketchboard Uno Arduino-compatible as the microcontroller. The lessons begin as a very structured guide to programming concepts such as:
Through the lessons, students will learn how to actually code an Arduino using proper conventions and methods in order to avoid much of the frustration often found in young programmers.
What fun is electronics knowledge if you can’t apply it. To that end, the course concludes by having students branch out into either Maker or Passion projects where they will tackle and solve real world problems with what they’ve learned.
In order to give you the needed flexibility to suit your classroom needs, we've developed two bundles - Basic and Expanded.
- Teacher's Guide download, including the lesson plan guide, the corresponding online slideshows, a self-reflection booklet for students to record their learning, and an assessment guide
- 4x Grove - Starter Kit for Arduino
- 4x The Solarbotics SketchBoard
- 4x USB-A to Micro-USB Cable
- 4x GM3 Gear Motor
- 1x Male-Male Jumper Wire Kit
- 4x GM3 Gear Motor
- 1x Grove Ultrasonic Ranger
- 2x Grove Tilt Switch
- 2x Grove LED Bar
- 1x Grove Moisture Sensor
- 1x Grove Temperature and Humidity Sensor
- 1x Grove I2C Touch Sensor
- 1x ARDX Plastic Tool Case
- 2x Slide Potentiometer
For more information on the bundles, email sales@solarbotics.com
Here's a tip submitted by Rick Steenblik regarding hacking our SCC3733 for less voltage, but more current: After using your SCC3733 solar cells for a couple of bots I noticed that they can be altered to provide about 3.3v at 80ma (in full sun) by cutting the bus connector on the back to electrically separate […]
We've received word from Dave down in San Francisco that the events are now over and that both Grant and Dave of Solarbotics have placed second and third in the mini-sumo competition!!! We would like to send our congratulations to them, and also to sneak some product out the door while they're still away and […]
These new Baby "Helios" Turbots by Grant McKee are an experiment to see how much can be done Turbot-wise with a single motor.
