USD $7.00
This is a really nice power supply. It's a switching DC supply so its small and light and efficient. It is thin so it fits in power strips without blocking other outlets.
The output is regulated so you'll get a steady 9V up to 1000mA (1 Amp) of current draw. 5.5mm/2.1mm barrel jack, positive tip. This supply is designed to work anywhere in the world, 100V-240V AC wall power, you'll just need a low cost plug adapter.
This adapter is now CE / UL listed
Great for Boarduinos, clock kits and Arduinos, anything that has a 5V regulator!
Great for MIDIsense, YBox2, Boarduino, clock kits and Arduinos!
Dimensions (wall wart):
Cable length : 146.05cm / 57.5in
Cable Diameter : 3.8mm / 0.15in
