USD $1.19
You want a massive, hefty push-button? Check out this 12mm square unit!
There are buttons, then there are buttons. As good as a tiny button is at resetting a circuit, or toggling an input, once you try this 12mm square beast, your fingertip will go "Ahhhh!".
The regular sized ones are good. These are great.
Weight | 0.001 kg |
Dimensions | 2 × 2 × 2 cm |
Type | |
Voltage | |
Current |
