New Stuff Friday: Canadian Currency, Lil...
Dave Hrynkiw
May 11, 2012
Welcome to New Stuff Friday, where we show off a smattering of the latest inventory we've brought in. How is this different from a usual Friday at Solarbotics? We've moved our other news/announcements to other days of the week (such as Project Monday and Cool Links Wednesday), so you just get the goods on the goods.
...Except for this week, where we have a (short) piece of news to also cram in. Canadian prices are now par with American prices. That's right fellow Canucks - with a few exceptions (such as Phidgets and Matrix Orbital inventory), the pricing across all of our catalogue is now the same in both USD and CAD.
And now on with the show:
Adafruit RGB LCD Shield Kit - 16x2 Character Display - Negative Adafruit RGB LCD Shield Kit with 16x2 Character Display - Negative
$24.95
This new Adafruit shield makes it easy to use a 16x2 Character LCD. This one features the negative display (colored text on dark background)
Adafruit RGB LCD 16x2 Character Display - Negative (RGB text on dark) Adafruit RGB LCD 16x2 Character Display - Negative (RGB text on dark)
$13.95
This is a fancy upgrade to standard 16x2 LCDs - instead of just having blue and white (or red and black), this LCD has full color RGB characters on a dark background! That means you can change the character display colors to anything of the following: Red, green, blue, pink, white, purple yellow, teal, salmon, chartreuse. This LCD looks strikingly good in person.
SparkFun Pro Micro - 5V/16MHz Leonardo-lookalike SparkFun Pro Micro - 5V/16MHz Leonardo-lookalike
$24.95
The Pro Micro is similar to the Arduino Pro Mini except with an ATmega32U4 on board. The USB transceiver inside the 32U4 allows us to add USB connectivity on-board and do away with bulky external USB interface.
Micromega uM-FPU64 64-bit Floating Point Coprocessor Micromega uM-FPU64 64-bit Floating Point Coprocessor
$24.95
Not wimpy 16-bit, or even anemic 32-bit - this match chip does 64-bit math while expanding the I/O capabilities of your design.
LilyPad Accelerometer ADXL335 LilyPad Accelerometer ADXL335
$24.95
This is a three axis accelerometer for the LilyPad system. Based on the ADXL335 accelerometer from Analog Devices, the LilyPad Accelerometer can detect joint movement as well as inclination and vibration.
LilyPad Coin Cell Battery Holder LilyPad Coin Cell Battery Holder
$4.95
If you're looking for a simple way to add a battery to your LilyPad project, the LilyPad Coin Cell Battery Holder might do the trick.
LilyPad Arduino Simple Board LilyPad Arduino Simple Board
$19.95
This is the LilyPad Arduino Simple Board. It's controlled by an ATmega328 with the Arduino bootloader. It has fewer pins than the LilyPad Arduino Main Board, a built in power supply socket, and an on/off switch.
LilyPad LED PCB Set LilyPad LED PCB Set
$4.95
These boards allow you to use your own 5mm LED as a LilyPad LED.
LilyPad Battery Connect LilyPad Battery Connect
$2.95
The LilyPad Battery Connect simply gives you a connection point for a battery or anything else you might want to plug in to your LilyPad system. It consists of a single 2-pin JST connector on a small LilyPad board with positive and negative terminals.
And that pretty much wraps up our first week with our new newspost format. Like it? Hate it? Rather ambivalent? Let us know! We're glad to take whatever feedback we can get. Now if you'll excuse us, there appears to be green stuff coming out of the ground, a bright thing shining down, and the sky is an alarmingly attractive shade of blue. It's a big improvement over last weekend, what with it's wide variety of Snow and Other Snow. We'll see you all on Monday with new project post!
November 13, 2008
HexPummer Lanterns!
Our K HP HexPummer has always been a good, steady kit, but once we got our laser-cutter, we started experimenting... and was it ever neat to tuck one of these into a faux Japanese-style lantern! After upgrading two of the four LEDs with super-crazy-mega-bright LEDs, this solar-powered night-activated light show is quite a cool decoration, […]
July 11, 2007
BEP Application: Bare Bones PhotoVore
We like to have some play time at Solarbotics, and the "Bare Bones Photovore" is the results of one of these play sessions. It's a very simple (amongst the simplest, we'll hazard to say) light-seeking solar-powered robot, and find it easy to build using the Bicore Experimenter's PCB.
June 11, 2004
New! Servo2 and RM1a motors
We've got in an inventory of Grand Wing Servo S03N standard servos. These pack quite a bit of power, and prove to be pretty good for standard servo applications. We're sorry to say that the RM1 is no-more. The RM1 is dead; long live the RM1. (I never understood that phrase...) All hail the RM1a! […]
November 3, 2003
Hmmm... what's that big truck bringing? ...
Well, what a pleasant surprise - a large truck dropped by today and delivered our shipment of GM10 gear motors! They're $12.00/ea or $9.50/ea USD in pairs ($15.50/ea or $12.75/ea in pairs for Canadians) - much less expensive than converting nanoservos!
1 2 3 253
