What's New At Solarbotics
Dave Hrynkiw
January 9, 2019
We've added new products to our website! Here's a quick look!
ESP-01 Programmer / Adapter Module
Programming an ESP0-01 (or any other ESP8266 variant) can be a bit of a button-toggling dance even after you get it wired up correctly. This handy little module makes it so much easier, by making completely buttonless and comes with a usb connector as well! Plug in your ESP-01 and use the standard ESP toolchain to do the programming. Just flip the switch to "prog" and start the programming procedure.
You'll definitely want one of these if you've ever had to breadboard a quicky-programmer adapter for these more than once!
  • 4.5-5.5VDC power input
  • 300mA working current
  • 5V USB-TTL compatible (3.3V Logic Level)
  • Selectable switch between serial and programming mode
Battery Charging Shield for WeMos D1 mini
Interface a lithium battery to your WeMos D1 Mini using this convenient battery charging shield! It comes equipped with a 1A lithium battery charger and 5V, 1A boost regulator for all of your power management needs. It is specifically designed for the WeMos mini and mini Pro ESP8266 based development boards. This shield includes two Male 8 pin headers.
  • Charging Input Voltage: 5-10V (5V recommended)
  • Compatible Battery Voltage: 3.3-4.2V
  • Charging Current: 1A Max
  • Regulator Output Voltage: 5V
  • Regulator Current: 1A Max
  • Charging Connector: USB Micro-B
  • Battery Connector: JST-Ph 2-Pin
Push Button Shield for WeMos D1 mini
This push button has a very satisfying tactile "click" and is a great place to start if you need a simple interface for your WeMos module.
  • Button Nub Dimensions: 4x4x3mm (LxWxH)
  • Included headers: 2x 8-Pin Male, 2x 8-Pin Female (short), 2x 8-Pin Female (long)
Pinout:
Add a micro SD card to your WeMos D1 Mini with this shield to increase your usable storage. This is excellent for storing stuff such as web pages, music or image files, or really anything you need to load or save that doesn't fit into the 4Mb onboard storage. It is specifically designed for the WeMos mini and mini Pro ESP8266 based development boards. This shield includes two Male 8 pin headers.
  • Card Size: Micro SD
Pinout:
  • D8 - SS
  • D7 - MOSI
  • D6 - MISO
  • D5 - CLK
    M3 x 14mm Phillips Pan Head Screw
    Screws. Yes, Screws. Small, METRIC screws. Because these are hard to find, especially in Calgary. So we took matters into our own hands, bought waaay to many, and now we're selling the extra...
  • Phillips pan-head (+), 5mm head diameter
  • M3 x 14mm long
  • Zinc plated steel
  • Package of 10
M3 x 16mm Phillips Pan Head Screw
Again, YES, screws. For the aforementioned reasons above (and there's more to come!)
Small metric hardware: M3 x 16MM pan-head Screws, Package of 10
February 23, 2018
New Product: WeMos
WeMos D1 Mini - 4MB Microcontroller $9.85CAD / $7.95USD  The WeMos D1 Mini makes working with the ESP8266 module simple! Breadboard compatible and equipped with a microUSB jack, build your next Internet of Things project in a snap. ProtoBoard Shield for WeMos D1 mini $4.39CAD / $3.50USD A prototyping area that comes with headers you […]
December 18, 2003
Still time to get stuff for Christmas...
There's still a bit of time left if you're dropping hints to your loved ones about what you want for Christmas! US Express -- December 22 (last chance!) Canada Express -- December 23
February 2, 2009
Red Lanterns Back in Stock
For all of you holding out to get your Valentine's Day Lantern in red, the wait is over! It's now back in stock and ready to order. You can get your HexPummer Lantern right here.
November 19, 2001
Christmas Specials
Time to stock up on Solarcells and Capacitors! Once again, we have our Solarcell Christmas Specials 1 & 2, and our Capacitor Christmas Specials online. Check the "Sale Items" menu pick for details!
1 2 3 253
