The Paris Flyer CarouSol Kit is the latest product in our line of solar-powered kinetic desk toys. Borrowing design elements from the golden age of air travel , we've added our unique solar-electronics flair to create self-powered dynamic mobiles.
Features
Designed as either a desk-mounted device, the Paris Flyer features wonderful visual detail when stationary. The periodic motion catches the eye, separating it from any standard mobile. The brass pivot rests on a low-friction metal disk for best motion.
The Paris Flyer uses our tried-and-proven SolarEngine technology that allows the use of solar energy in much lower levels than otherwise possible. Under standard office-level illumination, the hanging mobile version activates approximately every 4 minutes. In direct sunlight, activation is every 5~10 seconds, resulting in continuous motion from the mobile.
As a kit, the builder has an enjoyable experience assembling a precision-cut wood model, with the additional challenge of soldering the SolarEngine together. Being wood, it readily accepts almost any finishing method from lacquer to marker.
As with all Solarbotics' kits, it comes with the "No Fear" warranty. We guarantee the successful completion of your project, regardless of issue.
Specifications
Intermediate skill level - ages 12+
Basic soldering and tools required
Solar powered - no batteries needed
1-2 hours build time
Kit includes
• 4 x Laser cut MDF panel
• 1 x #4-48 plinth & screw
• 1 x 3/4" ball bearing
• 1 x Aluminum spinning surface
• 1 x Double sided sticky tape
• 1 x Propeller
• 1 x Pager Motor
• 2 x SCC3733 solar panel
• 2 x 13” long 30awg wire
• 1 x Solar Engine:
Grove - Loudness Sensor $7.68 Detect sound with this well-engineered Grove loudness sensor. Grove - Thumb Joystick $7.68 A handy Grove module thumb-joystick. Grove - 3 pin to Grove 4 pin converter cable $.588 Add your traditional 3-pin GVS (Ground / Voltage / Signal) device to a Grove plug. Grove - Servo Branch Cable $5.88 […]
What a cah-razy week we've had. We're officially all moved in at our new location. There are still mounds of boxes to unpack and things to organize and some renovations to finish, but, all things considered, it went pretty well. If you happen to know where my USB extension cable went, though, I'd love to […]
After a long hiatus, our PP3 chisel-tip pogo pins are back! And it looks like they're here to stay, so no more drop-outs in supply. I know that we use them for robotics applications, but there's a lot of people using them for other electronics purposes. Now you can get them reliably, and in quantity, […]
We've got 20 spots, and 17 seats are filled. If you're planning on being at the Seattle Robothon and want to get in on an introductory Sumovore Workshop, now's the time to check out the registration page! Read More...
Warning: This product contains chemicals known to the State of California to cause cancer and birth defects or other reproductive harm. Please visit www.P65Warnings.ca.gov for more information. This item was manufactured prior to August 31, 2018.
