We always enjoy seeing our products being modified, revamped and DIY-ed, as well as the results of these transformations.
Our customer Vera Kark provided us with some thoughtful feedback on adding mechanical tweaks to improve our Solar GraviTrack build and documentation. She also painted the brown MDF of the machine. She used tempera paint on the wood components still in panelized form, and the GraviTrack's performance seemed to be unaffected.
The GraviTrack looks great in vibrant jewel tone colours, however, we do not recommend applying paint to the hand mechanism itself. You can paint the base and the rails, avoiding the hand mechanism completely. The moisture and the thickness of the paint might affect the precise tolerances of the moving parts, and will interfere with its proper functioning. Another relatively safe option might be felt tip marker since the moisture from alcohol evaporates quickly.
Photos & video by Vera Kark
P.S. Also, a particularly bad idea is painting your GraviTrackafter the assembly is completed. Even though we were using a very watered down acrylic paint, the mechanism seized up the moment the paint became sticky. Don't be like us. Take care of your GraviTrack.
Just in time for the holidays we've come up with one more theme for the new HexPummer Lantern. Behold, the winter theme! It has a snowman, snow flake, a holiday tree and some holly to fulfill all your blinky festive needs. Better nab it quick - this design will only be around for a month […]
The Turbot is a member of the Scophthalmidae family of flatfish and is almost completely circular. Turbot is often found partially buried in the seabed in sand, gravel, rocks and sediment. Its fat content varies, but it usually contains roughly 1 gram of omega-3 fatty acids per 100g fillet. Barring advances in genetic engineering, we will not be building that kind of Turbot. However, this kind of Turbot can be built with a soldering iron.
We're not really into horoscopes that much, but generally we try to keep the company stars aligned. Sometimes, though, the stars do not align, and decided to go on spontaneous day trips to other corners of the galaxy. It's all well and good for the stars, but the planets really get confused and end up […]
We are excited to announce that it is now official - we are going to the MakerFaire Bay Area! Solarbotics will be in the Maker Shed May 17 & 18, 2014 with some brand new product. Come check it out if you are around.
Warning: This product contains chemicals known to the State of California to cause cancer and birth defects or other reproductive harm. Please visit www.P65Warnings.ca.gov for more information. This item was manufactured prior to August 31, 2018.
