Well, it's that time of the season to shut down and spend time with the family. Solarbotics will be closing December 21, 2001 at 4pm, and we'll reopen January 3, 2002.
Overview | ||
At Solarbotics, we've been getting quite a few questions regarding the "real-world" performance of our solarcells. Although we do have the official Panasonic Sunceram datasheets, it is written in a quite technical manner and does not include practical design data. With that in mind, we have generated the following - the first of three sets of data for use by the BEAM community. This first set of data is taken with direct-sunlight performance in mind. The second and third sets will be measured under halogen and incandescent lighting (stay tuned...). | ||
Data Acquisition Procedure | ||
Solarcell voltage across resistance values recorded on June 20 between 13:07 and 13:25. Solarcell capacitor charging values for capacitors between 1000uF and 4700uF recorded on June 22 Between 13:30 and 14:00.Solarcell capacitor charging values for capacitors between .047F and 1.0F recorded on June 25 between 13:25 and 14:10.Summer solstice on June 21, maximum sunlight at 13:37 (located in Calgary, Alberta, Canada).Testing apparatus consists of a basic stamp 2 for data logging and a ADC0831 chip for analog to digital conversion, 8 bit accuracy (0.02 volt resolution). When testing multiple resistive loads, relays were used to switch the load across the solarcell with a 200ms settle time. The basic stamp controlled sequencing and data logging by measuring the voltage across each switched load.When testing the charge rate of multiple capacitors, the capacitor was shorted by a relay for a period of five seconds, then released to charge by the solarcell. Voltage readings were taken between .2 and 5 seconds, depending on estimated total charge time. An 80% open voltage line is also indicated on the graphs. |
Charge Times sorted by Solar Cell | ||
Charge Times sorted by Capacitor | ||
Solar Cell output under Resistance | ||
Complete Data Sheet Download | ||
For those of you who would rather have access to the complete data sheets and charts for the 2001 Solar Cell Analysis, we provide this information in the Microsoft Excel format.Solarcell Data Sheet A - 88KB Solarcell Data Sheet B - 388KB |
Disclaimer: | ||
Although the information is provided freely, we request that any reproduction or reference to the above data be included with proper accreditation to Solarbotics Ltd. Additionally, although we have performed these tests in good faith, we do not and cannot warrantee this data in any way. |
In my recent wanderings in the world of overly-cheerful financial advise, I stumbled upon this budgeting theory that says that to feel comfortable about your moneys, or lack thereof, you gotta be living on your last month's earnings. Let's leave out the question of how anyone would pull it off, and just say that I […]
We were pleased to see the Kickstarter for Ringo, the Photopopper-ish but much smarter version of our own ~17 year old design robot kit. The video showcases some pretty cool behaviors, and is easily one of those projects where we think "Jee, why didn't we do that?"
PayPal payments are working again, thank you for your patience. We're currently aware of an issue regarding PayPal and are working to correct the problem. If you have attempted to place an order via PayPal, nothing has been preauthorized or charged to your account. If you need to place an order, please email sales via […]
