Motion Activated Tree Lights
November 13, 2015
In compliance with the upcoming holidays we decided to contribute to the obligatory dose of Christmas ornamentation in the shape of the well-known coniferous tree. A tabletop freestanding tree with LED strings and a flashing star on top seemed like an easy enough thing to do. We also wanted to add a tech twist to it and thought that it would be nice for the LED lights to react to motion and light up when someone approaches the tree.
First, cut out the tree shape out of whatever cardboard you have on hand, we had 3mm corrugated from broken down boxes. I used this image for reference and omitted the top ornament as we are going to make one of our own.
christmas-tree-silhouette-vector
We are making a 3-dimensional tree, so other than the shape itself you will need to duplicate the initial shape and add narrow vertical cutouts down the middle. The circular cutouts are for threading the LED strings through so you can drape them nicely. Here are the layout files for the image below (svg).
IMG_0386The photo shows the cardboard already spraypainted - assuming you want a green tree, not craft cardboard-colored. Once the paint is dry you can put the structure together as shown:
IMG_0384
Now wrap LED string around the tree in some resemblance of order. We tried it at least 3 times until we arrived to a satisfactory pattern that didn't look like it was made by a drunk finch angry at the fact that it has to deal with wire and not grass. For the tree that stands about 30cm (1ft) high we used 2 90-LED 3 meter strands in colors red-green-blue.
IMG_0390
Another part of the decoration is the treetop star. We wanted to keep the construction (relatively) simple without employing any fancy apparatus like 3d printers. So I cut out two identical star-like shapes out of a milk jug plastic and sandwiched a piece of vellum between them. It is held together pretty well with lots of CrazyGlue.
IMG_0458
The combination of opacities in milk jug plastic and vellum works well backlit by the sun...
IMG_20151106_164514
 .. and with the RGB LED that it is intended for.
It would be an inefficient use of our time and just boring if we were to make a plain old cardboard tree, even with lights, so in order to make it a little more interesting we made it motion sensitive. Don't worry, the tree won't get sick in the car and spread glitter all over your car seat, and ask you to buy a consolatory raspberry pi after. Instead, we added a contraption that contains PIR sensor that lights up the LED string when it detects movement.
bannerIMG_0377
Here's the schematic:
Christmas Tree 2015 Schematic (1)
 Theory of Operation:
The signal coming out of the PIR sensor is a pulse that can source 15mA.  That is plenty to charge Capacitor C1.  R3 is a discharge control for C1 to allow controlled discharge of C1.
R4 is a voltage divider circuit and is adjustable.  Both the charge from C1 and the adjustable input from R4 are fed into the LM386 OP amp.  This (operational) amp is configured as a comparator.
When the voltage on pin 3 exceeds the voltage on pin 2, the output on pin 5 will be high. When the voltage on Pin 2 exceeds the voltage on pin 2, the output on pin 5 will be low. Pin 5 is connected to the gate of Q1, a FET to allow higher current to flow.
 And here's what the final product looks like:
Considering building something similar? Here are all the electronic bits and pieces that we've used:
1 x 5mm RGB strobe LED
1 x 10k Resistor
1 x 1.0k Resistor
1 x ZVN2106 FET
1 x Audio Op-Amp
1 x 20k Multi-turn Trimpot
1 x Parallax PIR Motion Sensor (Rev B)
1 x 100k Resistor
1 x 330µF 16V Electrolytic Capacitor
2 x 3m 90 LED Strand with Battery Box
Or, if you prefer - add all of the items in one cart.
For other tools and supplies, you will need:
- a soldering iron
- some cardboard
- some semi-transparent material similar to the milk jug described above
- can of green spray paint
- box cutter knife (we couldn't resist the temptation and used lasers, sorry)
June 8, 2012
New Product Friday: Raspberry SAFE, IR S...
Friday! New stuff! Go! Solarbotics Raspberry SAFE $8.95 Now that you've waited a long, long while for your Raspberry Pi® board to arrive you'll want to protect your precious! Use the Raspberry SAFE to protect it from the harmful environment that is your desk. I2C-It Sharp IR Distance Sensor (10 to 80cm range) $16.45 We've […]
December 20, 2013
Friday New Product: LED Strings, Snowfla...
Festive occasions are right around the corner so we thought we’d treat you to some shiny stuff. In these times of heightened economic activity (I mean mostly gift giving) some super bright 2.8Watt LEDs and tiny SMD LEDs on a wire that come in a variety of brilliant colours might come in handy for the […]
November 16, 2012
Friday New Product, and Useful News on t...
Continuing in the tradition of mixing up the previously purely on-topic posts, we have a few things to announce today, other than bringing you still-brand-new-cool product. First off, the announcement from our Chief Geek: Make Something Useless Useful At Solarbotics, we put in substantial effort in creating kits for people to use to fulfill a […]
July 14, 2006
Make 06 Trimet
Eric L. was so kind as to send us a link to a video of his Make 06 Trimet on YouTube. If you want to build your very own Trimet you can get all the parts here, and if you don't have the magazine, you can buy it here. Order both together and get 10% […]
1 2 3 254
