Just a reminder that if you're still looking for that last-minute gift, you can still place an order prior to 2pm MST Monday via courier, and expect to get it in time!
Wee, more protoboards! Now this is the last batch, we don't got no more. Next time it will be something else, I promise.
PadBoard-1 Pad-per-Hole, 80x50mm Solder Protoboard $3.75 A tight and tidy one-pad-per-hole, plated-through, double-sided board. Ideal for wildly-wired, small projects! |
PadBoard-2, Pad-Per-Hole, 80x100mm Solder Protoboard $6.82 For the ultimate in protoboard flexibility, here's a one-pad-per-hole, plated-through, double-sided board from BPS. |
ProtoBoard2H-1, 2-hole Strips, 1 sided, 50x80mm $3.11 Long strips of copper too much for you? Complex zig-zags drive you nuts? Here's a nice compromise - solder prototyping with pairs of connected pads. |
ProtoBoard2H-3U, 2-hole Strips, 100x160mm Solder Protoboard $10.78 Long strips of copper too much for you? Complex zig-zags drive you nuts? Here's a nice compromise - solder prototyping with pairs of connected pads. |
ProtoBoard-3U, 6-hole Strips, 1 sided, 100x160mm $10.78 This traditional soldering protoboard is very similar to a solderless breadboard, but also accommodates a 96-pin VME backplane connector for slotting connectivity. |
StripBoard-1, 80x50mm Solder Protoboard $3.11 Medium size stripboard protoboard, featuring full-width solder points. |
StripBoard-3U, 160x100mm Solder Protoboard $10.78 Stripboard make for fast prototyping for simple circuits. |
SMTpads-Size1, 80x50mm, 50x50mil Pad SMT Protoboard $3.75 This 50mil-pad breakout is best for larger SMD components on 50mil or 100mil pitch spacing, with a ground plane. |
SMTpads-Size2, 100x80mm, 50x50mil Pad SMT Protoboard $6.82 This 50mil-pad breakout is best for larger SMD components on 50mil or 100mil pitch spacing, with ground plane. |
SMTpads-Size2, 100x80mm, 50x50mil Pads,SMT Solder Protoboard $6.82 This 50mil-pad breakout is best for SMD components on 50mil or 100mil pitch spacing, with a duplicate set of pads on the other side (no ground plane). |
SMTpads-Size1, 80x50mm, 50x50mil Pad SMT Protoboard $3.75 This 50mil-pad breakout is best for larger SMD components on 50mil or 100mil pitch spacing, with a duplicate pad arrangement on the backside. |
SMTpads-Size2, 100x80mm, 100x100mil Pad SMT Solder Protoboard $6.82 This 100mil-pad breakout is best for larger SMD components on 50mil or 100mil pitch spacing, with a ground plane on the other side. |
SMTpads-Size3U, 100x100mil Pads, 1 Side Pads, 1 Side Ground, Unplated Holes $12.99 SMT parts are pretty common. This massive 3U size solder protoboard features 100x100mil pads on a large 160x100mm surface. Has ground plane on other side. |
SMTpads-Size1, 80x50mm, 200x100mil Pads, SMT Solder protoboard $3.75 For REALLY large SMD devices, the 200x100mil pads on this smaller protoboard will make construction much easier. Has ground plane on other side. |
SMTpads-Size2, 100x80mm, 200x100mil Pads, Solder Protoboard $6.82 For REALLY large SMD devices, the 200x100mil pads on this protoboard will make construction much easier. Has ground plane on other side. |
It might be flying solar powered noodles, haunted samosas or gilded lardsicles... I highly doubt we'd have these exact items, but something not less exciting!
We're making the trip out to Robomaxx in Grants Pass, Oregon October 11-12. Gonna be there? Hunt down the dude in the cowboy hat wearing the "Solarbotics" Shirt. That'll be me. Maybe I'll have samples of our gearmotors burning a hole in my pocket. If it isn't me, tell him to give back my hat […]
Just in time for Christmas! This is truly one of the better beginner books about robots. It's a great gift idea... Read More...
So here's a late but tenacious Friday post with only 3 but mighty (brand new shiny) products. Not just some… random unrelated strange small bits… But much better! They are all kits. So they have more than one thing in them. Which is better than one thing... How about I stop mumbling the obvious and […]
