Superflex 3m 90 RGB LED Strand with 3xAA Battery Box
USD $17.50
Here's a simple battery-powered, portable and flexible RGB LED string solution. 3 meter, ~3cm spacing, powered by 3AA cells. Ideal for quick "BLING" effect!
SKU: 60678 Categories: , , , Tag:
Superflex LED strands are impressively flexible, constructed with an ingenious 7-wire-strand-over-nylon-thread wire that allows it to bend much more than a simple wire. You can add LED bling to wearables in a flash, and not worry about breaking any wires! The connected 3xAA battery-box features on/off switch, for easy control of the 90 LEDs on this 3M (9.8') long strand. No soldering required - just install batteries, and go!
This particular string features LEDs that individually cycle through Red/Green/Blue combinations of illumination. When turned on, they all start with the same pattern, then slowly fall out of synchronization to products a brilliant, oscillating multi-color lightshow!
Available in a multitude of colors, they're a quick and easy way to add some LED bling to your project, with no soldering or programming required. As opposed to regular 3m 90 LED Strand with Battery Box which use a firm thin enamel wire, these are super flexible and perfect for wearable applications.
 Flexibility comparison and RGB string demo:
Weight 0.04 kg
Dimensions 8.5 × 7 × 2.5 cm
