Friday New Product - MicroSD Adapter, Po...
January 4, 2013
Welcome to the first Friday of 2013. This is better than the first Tuesday, because as you may have guessed, after the first Friday comes the first Saturday! And that leaves me endlessly satisfied that everything is as it should be, and the new calendar doesn't need "convincing" for what order the days should go in. I don’t even have to use my throwing knives, I mean, bear spray. So anyways, there are only two products for today, but they pack the coolness of a regular set of six:
Low-profile microSD card Adapter
$5.95
Have an SD card that just seems to protrude from your project or application? Well, why not shorten things up by using a microSD card with this Low-profile adapter.
5V 10A Switching Power Supply
$25.00
5V is a common voltage but there isn't much out there in terms of a high current 5V source. When you are in need of a 5V supply with immense strength; we strongly ask you to consider this unit.
We also have an updated version of Double Rainbow RGB LED strip controller assembly instructions, which you can check out under the product's documentation tab.
May 8, 2009
Propellor, Maker Faire
Welcome ladies and gentlemen, to a special edition Evening News Post! That's right, it's way past the magical closing time here at Solarbotics but some of us are trudging onward. To what end, you wonder? Well, if you've seen that shiny orange promo banner up top you'll know why. MAKER FAIRE! Yup, just like the […]
August 14, 2015
Friday New Product - Grove and RGB LED B...
Grove - 2-Coil Latching Relay $12.84 The Grove latching relays are interesting because they take a pulse to toggle their state, which it maintains even after a power cycle. GrovePi Starter Kit for Raspberry Pi $116.87 Carrying a GrovePi+ board together with 12 carefully selected Grove sensors with 10 pieces cables, this starter kit gets […]
June 30, 2016
Iron Man & Solarbotics at Comic Exp...
We often work with people with very interesting projects. This time, it's an impressive Iron Man MkIII costume build, by Phillip Vatour of Calgary. Phillip had come into our offices one day and said: "You might be interested in seeing what I've been building with the stuff I buy here...". He pulled out his phone […]
April 29, 2005
ScoutWalker III Workshop
Space is Limited! RSVP as soon as possible! -- Solarbotics will be hosting another workshop to get you prepared for this year's annual Western Canadian Robot Games. The main attraction will be our almost-in-production ScoutWalker III Robot. The ScoutWalker III is an agile two-motor walking BEAM robot platform designed to take advantage of microprocessor-based brainboards, […]
1 2 3 253
